So.. I should test where it plugs in to the ecu.. I would assume that would varify the connector and the injectors are good or bad. Any one suggest a good meter.
Fluke makes the best meters, but you pay for them. Any meter should work. I use $5 meters from harbor freight with good luck. Check them against a few known sources (120v in the house, 1.5V DC battery, etc) and you should be good.
Check resistance value at the injector itself to verify the injector.
Check for continuity/resistance at the ECU to verify connectors and wiring are good.
HALLO
Lately i bought YAMAHA SX 230 ,year 2005 ,with 2 engines .I'm looking for hole electric box with wires .because i have only one ,box is called YAMAHA 6B6.
MODEL of boat SRT 1100-D. VIN YAMCS384D505
Computer in the box has these numbers :6P6-00, F8 T94874, 5129
Outer computer has these numbers : SH 678B-13, G4D.3
Do you have something like that ?I can send pictures if you like .
Iam looking forward for your replay .If you don't have it ,do you know where i can find it ?My mail is roman@wiertelak.pl
Kind regards,
Roman
