- Daytona Beach Florida
- SX
I have a 2006 SX 230 been having an issue where I turn key and get nothing then turn it again and boat starts fine. We went out on boat yesterday and when we went to leave turn key and nothing but a click coming from the main electrical box on back wall of boat engine compartment, the clicking was coming from under the panel where the battery wire goes in and starter lead comes out, I see there is a starter relay immediatly behind this would the relay just click if it was bad? Batteries are fully charged in boat other engine fires right up. Guess my thoughts are the relay is bad but I dont know enough about relays to know if it would just click if it was bad, part is $75 so i kinda wanna be sure it is it,
Another this i was able to get it started, I thought if I turned key on and jumped between the battery lead and starter lead it would start, it did crank but did not start, after that i just tried the key again and it started right up, (thank god i did not want to go home 12 miles idling on one engine against the current) when i got boat bat to house, same thing turn key and relay just clicked, did the exact same thing as before and it started with key. Thanks for any ideas and help
