Did they get the hours on the Connext to match actual engine hours? I got a Connext replacement and it shows roughly 50hours less than actualy engine hours.
No, same as you - the engine hours went to zero with the new CONNEXT. So my engine hours will always read 88 hours less than I actually have. The Yamaha dealer and probably anyone that has the diagnostic equipment can however read the acutal engine hours.
Ok... So thought I would follow up here. My dealership, Cyclesprings, has ordered a new Connext from the factory. It is supposed to have a new update to prevent this issue, and to top it off they are going to set the hours on the Connext to exactly match engine hours!!! YEAH! Hope this works.
So far so good! I got new Connext Back, it had the correct hours on it that matched the motor. I went out for a couple hours over the weekend with linked throttles engaged and everything tracked like it should!!!
Great news to hear, did the new connext and the new update automatically read the engine hours from the BCU or did the dealer manually set the hours on the connext.
Yes please get details of how this was done from the dealer. I imagine most dealers likely arent aware how to do it and there are several of us with hours not being displayed accurately due to connext replacement.
Thanks
Dealer tried update, but could not set the Connext engine hours after. So they read the hours from the motors and got another Connext from GA that was updated and had the hours set correctly right from factory. Now everything matches.
