FSH 210 Sport
- Tranquility Base
- FSH Sport
Cleaned up wiring today. Wired DVSR as per the diagram above, cutting loop and just routing it to load side terminal of start switch with no fuse. Put in a bus bar for all Negative terminals and routed 1 wire to the batteries, in which all 3 negatives are connected in parallel . 2 house battery positives are parallel. Start switch positive load side to battery. All HOUSE battery side positive lines put on a bus bar to consolidate and tidy up lines.
Thats awesome you put in buss bars! Something that I need to do myself! Be sure you test your dvsr set up!
