foreveryoung65
- 242X E-Series
I have a yahama 242x 2019 that suddenly started revving the starboard engine when I try to accelerate when I'm set up for surfing. The starboard engine can run up to 500 RPM's above the port engine for no apparent reason. It eventually settles down to the same as the port engine when I get up on plane. I checked the cleanout ports and felt around the impeller and there does not appear to be any dings or anything clogging. I have no recollection of anything getting sucked into the impeller. Is there anything else I should be considering for causing this issue? If I take the boat to the dealer then I'm likely done surfing for the year because they are so backed up so I really want to find a way to manage this myself. Much appreciated!
