rkluck
- Powder Springs, GA
- Limited S
The first year I had the boat I had a similar problem and it was always the port engine. The dealer worked on several times and even road with us to see it first had. It was just a pain when I was backing in to the slip and then engine would shut down right in the middle! Anyway, I finally figured it out, well at least it stopped. I didn't know that the bilge pump would just stop pumping after several minutes even if there was water in the bilge. So when I would run it and then when it stopped pumping water I would turn it off. What happened is there was a lot of water (to me) in the engine compartment. I saw this and thought not good, so I left the bilge pump (always do now) and after awhile the water was gone. Amazingly the problem has been gone ever since. I suspect the water was either splashing or just creating enough moisture to cause a problem. Now almost into our 5th year I have never had the problem again regardless of how we use the boat. This is just what happened to me.
