CarolinaJet
- North Carolina
My F150 w the 3.5 ecoboost and the big (36 gal?) tank occasionally worked out its estimated range to a bit over 600 miles after a lot of highway driving. That is crazy far. Even on a road trip I’d stop at least twice before covering that many miles. I get that the big tank is for towing range, but more than 90% of the time I’m not towing so I rarely filled it all the way.
Replaced the truck with a used Tesla model x which turned out to be a far more stable and agile towing vehicle than the F150. Weight is down low so it’s stable, suspension isn’t disturbed by anything, the shorter wheelbase makes for easier maneuvering into my storage space, and it has so much torque that I set it to chill mode when towing so there’s less chance of yanking the trailer too hard (I did it once by accident and am glad I didn’t bend anything!) It truly drives like nothing is back there. And to top it off, the immediate regenerative braking when you lift off the throttle is very confidence-inspiring when towing, and keeps you completely out of the regular brakes for all routine driving. The truck was rated for around 11k lbs but I ALWAYS knew the trailer was back there making it work, pushing it around, and feeling like an elephant when needing to bleed off some speed.
I’ll admit there are two significant downsides to the X. First is mirrors. They are really small and at first seemed like I was blind. I’ve found I can mostly offset this by using the rear camera with the side cameras turned on. And I got add-on mirrors that help in some situations. But nothing like nice tow mirrors.
And the big one is indeed range. My model x is a long range plus which claims 350+ miles of range with its 100kwh battery. But that is based on about 270 watt-hours per mile, a threshold that is achievable only when not running the ac or heat and staying off the freeway. Add in any of those things and it will be 300-400.
But towing my boat is more like 750-800 wh/mi at 60-65mph. So the usable towing range is right around 100 miles. Far too short if you do a lot of towing. For the 1-2 trips per year I take the boat more than 80 miles round trip, I have to supercharge and plan carefully. So it’s a trade off that doesn’t impact me too much, but would be a deal breaker if I were going farther than 1-2 hours away, or if I were doing medium distance regularly.
