Mainah
- Chapin, SC
- Limited S
I have decided to build sealed sub boxes between the inner and outer hull out of fiberglass as I can't find a way to fit a box in there. My access is from the speaker hole. I have closed cell foam stuffed all around to make the crude shape and am going to use spray foam (shaped after curing) to seal it up better prior to fiberglassing as something to press the fiberglass against. I will have to laminate multiple layers of fiberglass to about 1/4 inch thick and it won't be seen so it does not need to be pretty. I will also be mounting MLV on top of the fiberglass inside the box for a richer sound given the fiberglass box.. It just needs to stand up to the stress and air pressure of the sealed subwoofer.
My question comes in on materials. Would chopped strand or woven work better in this application? if chopped strand should I go with the thicker stuff to build up faster or will that be too hard to work with on tight angles/radius in a tight space. What kind/brand of resin will work best?
I have only done a couple of projects with carbon fiber or fiberglass but this presents its own challenges and I don't have enough experience to know what is best in this application.
-Edit My plan is to prepreg each sheet in a baking pan with a rubber roller so medium to long cure time will be best unless that plan has a hole I don't see.
