I_squared_r
- Medellín, Colombia
- 242 Limited S E-Series
I'm having similar problems. Had injectors cleaned, new plugs, and oil change this past fall. This year it won't go above 6500 rpm in the water where it normally goes 7850 I think.
I pulled the impeller this evening hoping it was jacked up but it's not. Can't figure this out.
Did you try running it without the air filter? Definitely isn't your impeller if you can't go above 6500 rpm. Something air/fuel related is choking the motor.
