Aslockcuff
Loads of fun! Where are you located?Looking at buy our first Yamaha jet boat. 2008 AR210. What am in getting into?
Thanks. We have had traditional IO boats before. Any tricks to the steering? How is the reverse? Also heard they are loud?Very, very broad question lol. After you get used to the steering you’re gonna love it!
Thanks. Charlotte NC near Lake Norman.Loads of fun! Where are you located?
We are near, on Lake Gaston. Steering is an ART and you need to practice. April-May are rough, but Sept-Oct are fun because you have had lots of practice steering.Thanks. Charlotte NC near Lake Norman.
Appreciate it! Looking forward to getting it out on the water. It has some pretty heavy keel scuffing but nothing through the gel coat so looking to put a keel guard on it. Assuming yours is a twin engine as well? Do you ever use one in reverse and one forward for turning?I have yet to have anyone complain with how loud my boat is (08 AR230). Definitely louder as I have been cursed with a mechanics ear, but it doesn’t bother me. First a foremost, only go as fast as you want to hit the dock and trailer. Also, you have to have some sort of thrust for steering! Go as slow as you want and don’t get pressured even if the ramp or docks are busy to try to go faster. I hit my trailer every time perfectly just by leaving the throttles in the forward detent and letting it idle to the trailer, this is also how I dock. I usually have to put it in reverse and give it some throttle to slow down since I haven’t perfected it yet but i feel I'm pretty good at docking anywhere now that I’ve got the hang of it.
When you slow down make sure you throttle down slowly, don’t just goose it to the neutral detent, you’ll probably end up dunking the front one day doing that, ask me how I know lol. I usually slow down and try to make sure I don’t have the water catch me from behind too.
Reverse is obviously not a true reverse, it’s just closing the buckets over the nozzle and forcing the water to go under the boat. It’s not as responsive and this is how my buddy found out you need to give some throttle while in reverse if you’re coming in too fast at a dock. So when I approach a dock pending wind and what not I usually go 30-45 degrees nose in, then put it in reverse and turn my wheel towards the dock to bring the stern over, usually have to give it some throttle at this time.
Once you’re in a slip make sure you shut the boat off, it has no true neutral. So make sure you have everything ready like dock lines and bumpers out prior to approaching the dock. Once you figure out how to maneuver you’ll be fine, I feel this is way easier than my old I/O for sure.
Search all over on here, you’ll find some good stuff in the drop down menu like the FAQ section!
Well for a very small amount of money you can own the water at all speeds in big waves and even when you are turning and decelerating at the same time. It is a huge difference and you get to sit back and enjoy the ride.Im ocean bound and I love my boat. Truth is that it steers like a basketball at low speeds (in stock trim) but you figure it out and become a better pilot for it. It's also very wide and shallow draft compared to more traditional boats so it catches the wind when you least want it too (at docking) and can get turned around but again you learn to be a better pilot and it's all good from then on.
I was referencing the 2017 19 foot boat as for the first one it only has slow speed part time fins I make super steering that works at all speeds and even stays in control during water sport activities and when in wind waves and currents plus it stays in control during rapid deceleration and is adjustable as well as made from tempered aluminum NO PLASTIC . But you know that you have had them on your boat for many years..The black boat in the pic looks like it already has fins. If this is correct good as the learning curve won’t be as steep as it would be without fins. Not just for the owner but guest drivers as well.
