jonw9
- Michigan, 48843
- Glastron
- GTS
I would still be curious to know if it has a hot automatic feature or a hot float switch. Can you see the pump? Does it have a float switch somewhere next to it? The only other test is to run some water into the bilge until the pump is in the water, and see if it activates it. I can't imagine a stock bilge pump that is 100% manual. That would not provide any protection whatsoever, you would have to be in the drivers seat, conscience, and aware you needed to turn it on for any water removal. Certainly there is more to it than that.
The website propaganda says "automatic" which led me to believe this was a manual override. I didn't see it sticking out when I looked last night, but I didn't crawl in looking for it either. It is a packed little engine bay. I will try again to see if I can spot it, and if all else fails try the water method.
Also OP, sorry for the thread hijack! LOL
