tdonoughue
- The Woodlands, TX 77381
One of today's projects was addressing the screws around the perimeter of the cleanout tray:
after I learned about rivet nuts existing here on the board. The screws are mostly stripped. Some aren't even holding anything. So I acquired:
I pulled off the tray, redrilled some of the holes around the perimeter to the right size so the rivet nut would just fit:
Fixed up the tool, put it in the rivet, squeezed hard and PING. Um, it came out.
So, obviously these are made to grab something much thinner than the fiberglass here (I suspected that--hadn't measured before I ordered, but thought, it's not more than 2mm, right? um, wrong).
And, the holes at the forward side of the hatch were not drillable...
So things were not going completely swimmingly. I readjusted the tool, squeezed less, and was able to get the rivet nuts to basically expand in the middle of the drilled hole and hold fast. So I drilled the rest of the holes I could and...
Put the tray back and...
Was very excited to be able to tighten most of the new bolts down solidly. Tray is much better than it was, but not perfect yet.
A couple of learnings:
- Probably needed more like a 1" bolt rather than the 1/2" I got. A couple of the aft bolts weren't long enough to grab.
- Since there was not enough material to drill the forward ones, I had to leave the screws there (not that they are doing much). But that now means I need two tools to open the tray. So, those new 1" bolts I will get? Will get them phillips heads...
- Considering a blind nut or something for the forward few. Maybe epoxy them on the inside or something. Still working on that (and open to ideas).
