FSH 210 Sport
- Tranquility Base
- FSH Sport
I attached an Excel file containing my data.
I hope it is self explanatory.
Hey TG,
I was chatting with a friend of mine who has some experience with sound deadening via his friend who has a marine business doing just that. I told him about your results and provided him with your spread sheet.
We both agreed that your db meter appears to have some issues since the phone app showed consistent results across the board.
The other thing he mentioned that his associate found was that materials such as sound down reflect the sound, however, the sound will in essence bounce back into the chamber where it was created, so one needs to have materials in that area that will absorb sound. So you can put sound deadening material like sound down on the bottom of the engine hatch and the bottom of the storage compartments adjacent to the engine hatch, but, some material like the egg crate foam has to be installed in other areas of the engine bay, like the sides of the engine bays as if you have opened those storage compartments while the engine you know how much extra sound comes out, to absorb the reflected sound, of course in addition to making sure the sealing surfaces are properly gasketted. He told me his friend would put egg crate type foam onto to canvas and put that in the bottom of the engine compartment under the engines to help absorb sound waves. There is also a material that he told me about that looks like egg crate material but it is coated so that it will not absorb water or other stuff so you can wash down the bay without it getting soaked. I’m checking to see if I can find that material right now.
I think that when I do this project I will put the sound down material on the bottom of the engine bay hatch, the storage compartment lids, the clean out hatch and the front of the engine bay. Then egg crate type material will then be put under the engines, on the sides of the engine bay, on the walls of the aft storage compartments and anywhere I can put it in the aft bilge. The whole engine bay an aft bilge are like one giant bass drum that sound will just reverberate in.
