FSH 210 Sport
- Tranquility Base
- FSH Sport
Did you try turning on the key without cranking the engine for about 20 seconds so the fuel pressure builds up for the injectors before you crank it.
Great suggestion!
On my FI dirt bikes I essentially do the same thing, on my bikes you bump the starter and the FI light comes on and you can hear the fuel pump run then shut off, then hold the start button down to start. On my boat I turn on bothkeys and wait for the connext screen to fully boot up, then hit the starter.
Im still thinking with that many hours and no valve lash check, tight valves are known for causing cold start issues.
