H2O Life
- FSH Deluxe
I am new to the forum, and I have recently purchased a Deluxe. I have seen some very inventive solutions for mounting a transducer on an FSH, and after reading about several options I ended up with the following. First I didn't want to drill any holes in my new boat (I am sure that will pass). Second I am mounting a Ecomap 44DV and I will be upgrading when my wife is not looking, so I didn't want anything not easily removed later. I want to say thanks to everyone for their post, as I borrowed and learned from your experiences. I hope this option adds to the discussions.
Angle stock from Lowes transducer mounted to lower angle removed 2 bolts from keel plate, added spacers, and re-installed 2 M8 1.25x70 SS bolts through top angle. Drilled and installed 2 bolts to join angles. Note: angles were trimmed and fit prior to achieve desired height/drop in reference to bottom of boat.
Looking aft
Side view showing standoff and routing.
Looking aft
