Grover70
- Ponte Vedra, FL
- FSH Deluxe
Hello,
I haven't seen any degradation over the last 84 hours of primarily salt water use, beaching the boat and hitting the shallows. Where it is mounted there doesn't appear to be any turbulence that interferes with the signal. Before I mounted it I wasn't really knowledgeable about transducers, just what I read. I had not seen anyone do the same thing I had done yet. Using the seaboard to push the transducer about 1.5" away from the keel helped to get it away from turbulence I think. Any further away and it risked being the weak point.
I wrapped the cabling to protect it from wear/tear, fish hooks, etc. and used two points to secure the transducer cable for strength.
When I mounted the transducer, I used a jack to push it against the hull for 24 hours for the best result. I wasn't shy about using the epoxy and liquid nails.
Good luck!
Good luck!
