Has a choke but won't start with choke fully on. have to cover one carb, doesn't matter which one for a second and then it starts right up. I let it run for a little while and turn choke off. Seams to run good on the trailer at this point. But if you shut it off you have to cover one carb without choke to start it.
For Kawasaki SXI750 1995. For Kawasaki STS750 1995-1997. For Kawasaki STX750 1998. For Kawasaki XIR750 1993-1997. For Kawasaki XI750 1998-1999. For Kawasaki ZXI750 1995-1998. For Kawasaki ZXI 900 1995-1997.
The only other thing maybe an air leak around intake someplace or crankcase seal? Going to spray some starter fluid around while running and see what reactions I get.
If you had a air leak or bad crankcase seal it would cause a "lean runaway".
Just curious, what rpm is the engine idling at on the trailer? It almost seems like it is set too low, so the throttle blades are barely open and causing hard starting issues because it isn't drawing enough fuel through the carb when choke is activated.
Along that same train of thought, confirm your choke plates are fully closing when pulling the choke knob.
Fully closed but there is a 1/2 hole in choke plates so I covered all three 1/2 holes and with choke on starts right up. Not sure why choke plates have a hole.
The thing here is you shouldn't have to cover them to start. In factory configuration with properly setup carbs and mechanically sound engines they should easily start without issue.
This is why I asked what RPM you are idling at. We can't assist if we don't get answers to troubleshooting questions.
Put it in the water today. Starts right up with choke (holes covered) able to turn choke right off idles normal. Didn't notice rpm I would say around 2 to 3k. Runs great, very fast, no missing.
Let me humbly suggest you feel whatever you used to cover those holes are VERY WELL SECURED so they don't ever fall off into the intake while the engine is running. It is NO BUENO if debris enters the intake while the engine is running.
