- Acworth, G.A.
Kinda hard to explain. . . . but it sounded more like there was a vacuum created in the tank. When I disconnected the vent line, it sounded like it sucked IN air v.s. expelled it. It is possible the vacuum created by running the tank so low closed the check valve?
Full disclosure, . . . . . . I had ballast filled in that side of the boat for surfing this weekend. Could there be some correlation?
