we got a 73 degree day here yesterday, so yesterday afternoon I did some additional sanding on the problem areas a then re-polished. I'm now very satisfied with the result. Can see any scratches with light on the hull at night. :
The advice from
@tdonoughue &
@mrcleanr6 was all very helpful. When I re-sanded, I just checked my sanding from various angles/lighting before moving on. I'll remember the guide coat suggestion mentioned whenever repair the lower bumper on my Camaro. I'll be working with paint rather than gelcoat for that but feel like I've gotten comfortable with my Bauer Rotary buffer working on the boat.
Things learned:
1.) Don't be scared to use a rotary buffer! Do your homework and ask others for advice as needed.
@mrcleanr6 eased my mind on this earlier in this thread when he explained the different pad materials and what can get you into trouble if you are not experienced (burning paint of gelcoat). I had no trouble using Meguiar's M100 polish, a 100% wool pad, and keeping the buffer moving while working. I ended up going up to about 1400 RPMs for the final polish.
2.) Be patient and take your time on the prep work. I found the compounding/buffing/polishing to be the easiest part of my repair. The prep work is key to coming out with a good repair. Take your time wet sanding through the necessary grits to remove all sanding scratches as you go.
3.) When repairing a scuff on the left rear corner of the boat, I burned through the gelcoat to while wet sanding (gelcoat must be super thin on those corners). To build it back up using only the gelcoat paste, I brushed on a thin layer of the paste with a small paint brush. Then I hit the applied gelcoat with a hair dryer on the warm (not hot) setting. Then repeated this process for 3 or 4 thin layers. When re-wet sanding this area after it was dry, I started with 1000 grit and sanded, slowly working up to 2000 grit, taking care to not sand to much again. Then did the final polishing with the M100 & buffer, and then some by hand.
Pic after first repair a little to aggressive sanding:
Pic after the process I outlined in 3.) above:
This is the ugliest repair on the boat and I'm still very pleased with how it turned out. This area was a bI$%h to sand and polish due the curves AND the proximity to that pin stripe. Lots of masking tape was used around this area while sanding. You can see the gelcoat with built up a little higher there, but looks much better than the scrape that was there from the dock.
4.) For this type of work you will require a beverage our two. May I recommend the Yuengling Hershey Porter if you doing this type of repair in cooler weather.
Once again, thanks for everybody's input and assistance. I'm very pleased with the outcome........and if I happen to pick up another ding in the future, I'll know how to fix it now!
