Glastron Oil Change Kit For Glastron 187 GTS
Fitter0104
Glastron
GTS
Need help finding what kind and where to buy a oil change kit and filter for Glastron 187 gts. Also need to know where and if I need to change wear ring. If I just need to get these parts on Amazon and it's the same as a jet ski please let me know. I've seen full oil change kits but didn't know if it's the same. Also does anyone know how to order parts for these boats. I need a new bolster mine cracked. Thanks
For parts, I use the parts breakdown on Glastron website, then I use local dealer to order. What year is your boat?
For engine oil:
In cas you don't have this: new in 2016.
Thank for help. The boat year is a 2014. I wish there was a way to order boat items instead of through a dealer. The dealer by me is terrible.
Does anyone have problems with the rope constantly popping off of eyelet when toeing a tube. It seems like a bad design.
If you google XPS oil change kit, there's more than a few out there. Mostly labeled SeaDoo, but should be the same engines. Just find the one that corresponds to yours.
Might try searching for a shock tube for the rope. I haven't tried one yet or towed any tubers but haven't had any issue with ski ropes and skiing or hydro slide board
Totally agree on the lousy design with the eyelet. We ended up making a small knot in the loop of the tow rope. The smaller hole and bulk of the basic knot did the trick.
