Adrian @ JB Solutions
- Tampa Bay, FL
- 252SE
I would go free air.
The right tools are everything and at $100 its easy.
That price isn’t bad at all, I would have figured much more.
Didn't want to start another thread:
Might be a silly question, but I'll have to run a negative wire from the helm where the amplifier is located all the way back to where the battery is located since there isn't a metal grounded frame (like a vehicle) to tie into locally, correct? I can run a local busbar in the helm to tie in multiple amplifiers with one home run to the battery compartment. Or, is there already a ground local to the helm that I can tie into and not have to run completely back to the batteries? That 1/0 tinned OFC copper ain't cheap....
yeah, you are going to have to run a ground wire all the way back to the battery. There isn’t a ground wire big enough under the helm for an amp. As for the bus bar. Yeah, you can run one wire up to a bus bar and then have multiple wires coming off that (just watch out for the gauge wire you use and amp requirements)
Looking into the subs now and I know you mentioned free air. Is there a particular (best) place to mount these types of subs in our boats? Was planning on keeping everything kicker, but am open to whatever sounds good and the best place to cut a hole. And then there is what size of sub to go with in a 21' boat. I'm not trying to rattle my teeth or win competitions. Just want to round out the sound with the 8's i'll be installing.
On my SX210, I put 2 10's under the bench seat. You never knew they were there.
Good sound in that location? A lot of what I'm reading says to go enclosure instead of free air on a boat. Thanks for the info.
