- Raleigh, NC 27614
- 242X E-Series
I believe that would be the case, it should work better, w/less stress on the bow cover fabric.I wonder if these would work even better on a 242 X? @swatski Attach it to the front of the bimini frame for the bow...might give it better lift?
When trailering, I just disconnect the two pulleys from the tow point and tether them up (w/ carabiners) so they wouldn’t thrash around in the wind.
If in a driveway, I use a ladder. On/off ramp I do it while pulling the cover on.How do you do that with the cover already on?
I'm with you.After just buying a new cover I almost threw up when I saw you cut that hole
I'm glad it made it in time for your vacation. Have fun, be safe, and report back. ?They came in the mail last night. I purchased 2 for the 212x. Real nervous about cutting the holes, any other insight before I make the "surgical" cuts?
Its no lie when they say a boat is a hole in the water and you just keep throwing money into it...3 packages arrived yesterday in the garage and she the "Admiral" didn't even blink an eye... Thanks to @J-RAD for the Rope and Hydroslide, going to try out both next week on Keuka Lake.
New surf rope: O’BRIEN CORE SURF ROPE | Transom Watersports
O'Brien Hydroslide Versa 2: O'BRIEN HYDROSLIDE VERSA 2 | Transom Watersports
Hangtyte Support System..
Use quality curved-bladed scissors, very sharp. Cut conservatively, can always enlarge the hole but hard to go the other way.Real nervous about cutting the holes, any other insight before I make the "surgical" cuts?
