Jeff, thank you again - I think you put us on the right track here!I do not think a flapper valve will solve the issue here is why, the exhaust is below water and the water pressure on it is greater than the one that is on top so a flapper valve will not reduce the pressure being exerted on the exhaust gases, I doubt it is water entering the water box as much as it is back pressure against the exhaust trying to escape against the water pressing holding back the exiting gases, they are being compressed more than the other engine.
A snorkel would allow the gases to blow out the water and then allow the exhaust gases to exit with no resistance to start, then the snorkel could be pulled off to operate the boat . You could use this to start the engine rather than empty the ballast.
I find it convincing that when the ballast is empty the engine will start, so that in effect has reduced the back pressure by bringing the engine up higher ,it Just sounds logical to me, if it were not for the person behind the boat exhaust extensions would be the answer but since a person would be breathing this I would think just a temp incretion of the snorkel to start the engine and then pull it off so the exhaust goes under the water. If I understand the issue correctly the lower engine is having trouble restarting when it is so far below the water surface the temporary snorkel would be a lot better than emptying and refilling your ballast bag each time.
Another way may be to install a temporary snorkel in the exhaust to bring the top of the snorkel half way up in the water to some place close to where the exhaust is supposed to be when there is no ballast this would apply the same water pressure on your exhaust system as normal operation and keep the exhaust under the water where it would normally be.
Also my potato in the exhaust pipe reference was what people did to keep someone from starting their car it blocked the exhaust gases and the engine could not breath, air not going out will prevent the air from entering also.
Sure. But the depth of engine exhaust does not change between 5-10min (easy start) and 15+ min (very hard start) - of the same engine.@swatski, I believe Jeff's point is that the deeper you go in the water the greater the pressure due to an increase in density in the water. The engine is effectively a pump moving air from the intake though the exhaust. As the exhaust is lowered into the water the "back pressure" increases. At some depth the engine would not be able to start at all. If the exit of the exhaust is elevated the back pressure will decrease. I am uncertain how much the pressure increases due to inches of change in depth but there must be a reference somewhere. If this is the issue then a flap would not help as the pressure against the flap would increase as the depth increased.
I am hopeful that the issue is not the water pressure but the volume of water in the exhaust which the Dr. @swatski Flap would reduce.
I do indeed smell gas! At least I think I do, can be hard to tell when on the water. But just like you would in a fuel-flooded motor - immediately reminded me of many a struggle I've had with my old carbureted two strokers.next is the rich fuel mixture due to less exhaust breathing and less air intake so due to that, I think the plugs may be getting wet as the combustion chamber cools down adding to the issue is when the fuel system applies more fuel than the engine can use to start because of the increased back pressure .
Yea what he said !!! Run the blowers this isue was talked about a lot when the 1.8's came out and a lot of people found that when they ran the blower is stoped it , then after they got some hours on the boat it also stoped itDoubtful the issue is backpressure - the 1.8l can be hard to start when hot.
Running the blowers seems to help to cool the engine compartment...
Yea what he said !!! Run the blowers this isue was talked about a lot when the 1.8's came out and a lot of people found that when they ran the blower is stoped it , then after they got some hours on the boat it also stoped it![]()
