My 07 AR230 HO Has no accessory power and the engines have no power. I tried a new charged battery and a jump box with no luck and still no accessory power. Any ideas or tips would be greatly appreciated.
There should be a big fuse on the wall of your battery compartment. Follow the red wires until you find it.....my bet is it is blown. WHY it is blown is a whole different discussion.....did you just connect the batteries? Perhaps crossed a wire? Or was it running fine and then this?
I checked the fuzes in both black caps under the engine bay. All fuses look good after pulling them. The battery was charged full two weeks ago and reinstalled. That said, the boat wasn't started or checked for power after the instal. Now even with a high power jump box I still have 0 power to the accessorize / engines.
There is a fuse inline on the cable coming from the battery in the battery compartment. You would never know it is a fuse because it’s near impossible to see. It has a holder. Follow the line directly coming off of the battery and look for the holder to pop off the cap.
Did you clean your battery terminals? If not, I'd recommend taking them off, wire brushing them off, and reinstalling. Then if you still don't have power, it's time to take a 12V test light or multimeter and start tracking it down like that.
Battery ended up being bad. All the fuses are good because it was installed properly, no crossing of the lines. Now I have power but the engines will not actually start.
Does anyone know if the fuel pump kicks on with the keys in the accessory position or does the key need to be fully turned ?
One of the switches at the cleanout plug area is stuck in the down position. Maybe I should just replace both of them. I should probably buy spark plugs as well.
Anyone know where to buy parts without spending a fortune.
