@help 07 AR230 HO - no power
One of the switches at the cleanout plug area is stuck in the down position. Maybe I should just replace both of them. I should probably buy spark plugs as well.
Anyone know where to buy parts without spending a fortune.
Yamahasportsplaza.com for parts. Those switches are expensive and you will need to unscrew and pull up the cleanout tray to get at and replace the switches. Don’t forget the nuts too.
I thought the switches were separated to each engine side. The good switch should allow you to crank that side. Check Neutral switch too. jiggle the throttle lever in neutral to be sure.
