Ok guys , got it fixed. Thanks for all the responses. On an e series there are switches on the throttle servos to put it in "manual " or "electronic". If the buckets are not both up it goes into limp mode. To fix it flip the switches to manual and raise both buckets, while holding the buckets up flip the switches back to electronic. And that's it fixed! Thanks again guys!!
Thanks! You saved me from a terrible day in the water. Indeed I reset to Manual, moved the buckets by hand, then hit the switch back to Electronic, and fixed the problem. Thanks again for the prompt response ??
