Shans
CorrectYour battery is connected correctly, the switch is on, and the battery has charge and the screen won’t turn on?
NopeRemoving the pump will not affect the starting system in any way. Does the radio come on when you turn the key?
Yea. Battery is good. Brand new , fully charged.Can you check the voltage?
Just noticed now that there’s water in the battery tray though ??
Yes everything is working but the stereo, and found that fuse in behind and blown as well.At least the engine started. Is the Connext screen now working? All gauges working? Everything but the stereo working?
It’s the starter solenoid! I had this problem with mine at the beginning of this summer. Literally turn the key and nothing happens.
Dealer said they couldn’t get the part because of their supplier….so I ordered the part my self and then the dealer installed it. This is a warranty issue.
If you turn the key enough…eventually it will work. But you just have to get it to make the connection.
thanks for all the help everyone.
Thank you very much.Enjoy the water tomorrow with the family!
