Guy in a Boat
- 242 Limited S E-Series
Got in the lake yesterday and the engine compartment flooded and cut out the port side engine. Totally my fault, I have a really bad habit of pulling my jet clean out plugs to drain the water off the top and not installing them right away and I forget, which dumps a TON of water in my boat. Usually we dock on lake 1 and I catch it very quickly. This time we docked at lake 2 and took the channel over to lake one which takes longer at low wake speed. When it cut out I had the family and 4 small children. I opened the hatch and seen water to the valve covers so we all kind of freaked out just a bit. The starboard motor turning made it look as if a lot of water was coming in so we took off back to the dock on one motor. I didnt event think about the port side air box being lower and sucking in water. Anyway, the boat is home and all checked out. My port starter will engage the flywheel and tries to spin up but the motor will not move even with plugs removed. I put a fan on it all night and will check it again shortly. I have scanned through the forums and most I find people have flooded the compartment and things end up ok, I hope this is the case for me lol
