robert843
- Myrtle Beach, SC
I'm by no means an expert and its tough to see in your pic. The two larger red wires are the positives to your engines if I remember correctly and I'm just assuming the two larger black wires are the negatives to your engine is one of those negatives sandwiched between the others wires in there if so there maybe some on the negative terminal that don't belong and it may not be allowing the engine to ground properly. Try pulling all those wires of the grounds except the two engine wires and see if it works. Once again I could be very far off on this as there is a chance that may not matter.
