Yes,I was planning to add fuel and air separator .I have a kit that I ordered from group k but have not installed it yet. Now may be a good time to go ahead and do it
What are you doing with the choke while it’s running? What are you doing with the throttles?
I always use throttle to start the engine.
Partial choke can be used to diagnose a lean condition. If part choke makes the engine run better then it’s lean for some reason.
Just to be clear and for future reference... cranking is when you have the key turned to start and the motor turns over. If the starter is not turning, you’re not cranking.
Good luck. They are simple engines, but not very domesticated at idle.
