I am still having sporadic trouble with this engine.
It started right up in the driveway, we took it to the river, rode around for a half hour then shut it off at anchor for about three hours. It cranked and cranked without starting; then several minutes later it fired up again.
Here's what I've done so far:
- Oil level checked and is fine now
- Pulled the spark plugs on the port engine.
- Verified gap
- Verified spark (this rules out the lanyard safety as well as other spark issues)
- Spark plug color/etc good
- Verified it's not the cleanout port switches; had someone push the buttons down completely while attempting to start
- Attempted to swap fuel lines between engines; unfortunately the starboard fuel line was too short to reach the port engine fuel line attachment
- Batteries are good and ALWAYS fully charged
- Removed air filter during troubled starting; no difference
I'm almost out of ideas. Sometimes it starts right up, sometimes it doesn't. I'm really afraid that I'm going to end up burning out the starter.
I'm thinking of putting a bunch of fuel injector cleaner in the tank and see if that helps at all. What's the best stuff to use?
There was mention of a fuel filter. I can't find a fuel filter on the boat?
Anything else I can check?
