- Corinth, TX (DFW)
I wouldn't be set on vapor lock yet,
I would get a YDS, recreate the problem and then pull the fuel line and have the YDS pump fuel,
also, not specifically stated, you tried starting it with the engine hatch open? we have had a couple of exhaust leaks that starved the engine for air.
also, your problem of issues idling ok and higher rpm problems still make me wonder if there isn't debris in the tank that when you get lower on fuel is getting sucked up to the filter/screen. a previous post said you put in 5 gallons and it ran great,
have you tried to associate fuel tank level and the engine problem ?
