Yamijunkjones
2017 ar195, 1.8 s/c. runs great all day no hiccups or loss of rpm or any issues for that matter. That is until your shut the boat down for a minute. Try to start this mofo back up and you’re stranded for a solid 30 minutes cranking away until finally you’re lucky enough to get it to fire off. Then your back to trouble free boating. Just don’t shut it back down or you’re stranded again.
boat cold, starts no problem.. every single time
Now I know people are going to chime in saying oh these are always hard to restart hot blah blah, sounds like vapor lock.
well this is not the case. First of all your fuel pump is submerged in fuel not drawing a vacuum on the rail so vapor lock doesn’t seem logical unless someone can give me a logical explanation otherwise.
Fuel pressure maintains 53 psi hot at rail
Fuel injectors have been removed, flow tested, leak down tested
Valve lash is perfectly within across the board
Compression 135 1-4
Leak down tested held
Clean spark maintained when hot
Cam sensor has been replaced
Ecm has been swapped with good know unit (no change)
Etv angle is 6%.. usually they sit around 4% so I’m not ruling this out yet. However Yamaha says 3-7% is fine
I’ve checked for vacuum leaks, disassembled intake manifold to check delaminating on Etv isolator.
Engine temp in YDIS shows 180 F when I’m out beating on it, I’ve confirmed this value with my infrared flir gun at the temp sensor.
none of my values are out of range on my sensors everything from service manual to Yamaha support line is within spec.
I’ve also tried unplugging each 5v reference sensor 1 at a time while the engine was hot to see if the engine would kick off when hot (no luck)
I know there is a wizard out there somewhere that can make since of this sorcery, please chime in
Compression 135 1-4
