biffdotorg
- Pelican Rapids, MN
- Limited S
That’s the right question to ask. And only the channel you are navigating will tell you the answer. The key is understanding where the water intake to your cooling system is. Just sucking it through the pump, not necessarily. But into the intake, where it is on the pump can cause overheat issues.Does sucking up all that sand and silt and vegetation impact the cooling system at all?
For those of us that have ever had an overheat issue, will understand, that just sand, no, unless it is ultra fine. Check out the mesh over the intake. Again, if you are putting along and creating that sand vortex. And at legal, no wake speeds, that is a consideration. If that channel is weedy, it’s pretty much game over. Not only may you have overheat issues, you will then have cavitation and plugging issues once you do get out of the channel.
I feel very fortunate that our channel is very clean. So your mileage will vary and it is a case by case basis.
