- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
Sideways pivot is fine to about 90 degrees and 45 degrees aft on either side. The rebar is fine but I wonder if it will be as resistance to bending as rolled steel? I used 3/8" bent 90 degrees and welded to the anchor as a triangle point. It allows more movement to the back and less to the side. Test it so you know how much movement you have before welding. Also, the cold galvanizing spray paint is zinc rich, and will serve you well if you don't hot dip it. Just don't let any scratches open up. Sounds like you have it working!
