I have 2 blowers. From what I’ve been told, one sucks, one blows. Not sure if that is correct, but if it is, I guess I could use 87a. I need a wiring diagram for a12” connect. My bilge switch is touch screen, so I need to find the relay for starters.
They both blow out, at least mine do. If you are trying to tap into the blower circuit, do it at the blowers and not at the screen. That is where the fume detector will be mounted anyway. Wiring the fume detector/activator circuit in parallel to the blower circuit at the blowers should work, Although, I don't know what system you want to install.
Yeah, not even thinking of connecting at the screen. Those switches only send a signal, no switching. I need a wiring diagram so I can find the relay. I don't want to start pulling relays and setting codes.
Now that my fume detector is installed, I'm going to wire it to the blower circuit. I want to make sure the blowers continue to operate in auto and manual mode in addition to being activated by the fume sensor. Without a wiring diagram available, I'm going to use the color code chart that @zipper was kind enough to share with me. Being that I have the 12" connext screen, I don't want to be probing too much with my multimeter. I will ohm the circuit from the helm to the blowers to confirm the circuit. I want to make sure the blowers don't get activated simultaneously and the controls are independent of each other. Any insight is appreciated in advance. Thank you
Have you tapped into the circuit? How did it go? I would tap into the circuit with the fume detector blower control wires with a parallel circuit to the blowers. Not a series connection.
