I have little oil in cooling water....
Mr.Happy
Chaparral
VRX
Hello, i change today the carbon ring, by this projekt i have found another problem.
I think, i have oil in the cooling water (see picutres). Now, I do not know where to look.
The oil level from engine is normal, i have no water in oil.
Has anyone an idea, or something or see simliar?
Have erveryone a idea where i can search/test?
Clean it out and keep an eye on it, if no water is in the oil no problem, never had anything like that when I had 4 tec engines, maybe someone in the past put something in the cooling system by mistake, who knows but not having water in your oil is the main thing.
I think to do nothing is not the best idea for this problem.
The best news, i have no water in the oil. :-)
I check the oil cooler, this is tight. The others would probably be water pump and cylinder head, these are complicated places.
I think it is better to find the leak is better for oil cooler, cylinder head, cooling plate, do not want the engine overheating.
A leak is a 2 way street if oil was leaking into the water, water would be getting into the oil.
