I need some advise....
bobbie
Georgetown, TX
X
so morgan and i are considering relocating to a warmer climate after our daughter graduates high school in a couple of years. A must is a close lake or river with warmer water for our beloved surfing. So far...here's a couple of ideas....must be close to a mid size city at least... lower cost of living than the portland, or area (which is pretty high). Please add any thoughts....
1. Austin area (although the property taxes are ridiculous)
2.tuscaloosa
Tuscaloosa? @Bill D lives there.
in my opinion for surfing, Lake Martin would be better(wider, larger body of water) Lake Tuscaloosa is bit narrow and Long. Not a whole lot of places to anchor as most of the area is so deep. Water is fairly clean!
Writing from the Houston area here. One thing to realize is that in Texas all lakes are man-made (with a single exception on the border). Just to set expectations. Depending on how old the lake is, you will have stumps and you may have a lot of silt in the water. Not your crystal clear venues, generally. But, by the same token, that usually means that there are dams controlling the water levels which can provide you (sometimes) some better consistency in water levels.
Here in Houston (and all coastal), you will have high humidity with those high temps that will be, well, yucky for you. Not to discourage at all, but to set expectations. Austin is much less humid and comfortable. You may consider San Antonio, as well--but Austin is closer to lakes, generally.
Dallas area has several lakes, several of our members there, you don't have it as humid there. It gets hot and it gets a bit cold (for us) up there. So you might consider some suburbs up there or something around a lake up there.
You note high property taxes. You should also note an absence of state income tax in your computation. Also a very conservative, generally Republican populace (not saying if that is a plus or a minus--just stating facts, folks). Austin area is less so and an anomaly in the state.
We boat on Lake Conroe mostly. If you are in the neighborhood, drop us a line.
Since you mentioned Tuscaloosa why not come a little farther east to the Columbia, SC area. We have Lake Murray, great lake for boating; plenty of big coves to enjoy water sports and plenty of open water to run around on. The are also a number of other lakes within 1 or 2 hours to explore.
Plus's
Taxes are low, compared to Portland
Cost of house is low, compared to Portland
Columbia is a mid-size city with plenty to keep you busy
2 hours to historic Charleston, 3 hours to historic Savannah, GA, and 2 hours to Charlotte, NC (closest major city)
2 hours from the ocean, 2 hours from the mountains
Ask @Mainah about the area, he is in the process of moving to Lake Murray from Maine.
@Andy S @bobbie Wait, if college football is important to you, go with Tuscaloosa!! Haha just had to get that in there lol!
Just to clarify, the current college national champs are in South Carolina and 3 hours away from Lake Murray. Yes I am a Gamecock fan but Clemson did our state proud. :winkingthumbsup"
We have been on Lake Livingston since 1998. It is a huge lake (about 99,000 acres). Average depth is around 40 feet, with the deepest in the area of the damn approaching 100'. It is a man made lake, and as tdonoughue stated, stumps can be a problem. We stay in the lower half of the lake, and it is pretty clear. You have to get to know the area! The one thing good that has happened lately was after a major hurricane, the lake level had to be lowered over 6 feet because of repairs to the area of the earthen dam. While this was done, a company came in and removed a lot of trees/stumps (350) in the more populated areas. This was paid for by individuals. The stumps were cut 10 foot below the water level at the time, which makes them 16' below normal lake levels. That has helped, but you still have to be aware and do your homework. Since 98 we have had no major issues just by boating smart.
Some advantages: There is PLENTY of property available. Prices have risen considerably since we bought, but still cheaper than the Austin area. Property taxes are not bad either, depending on the county you are in. Most of the time, the water is pretty clear, for a silt bottom lake. Although more crowded now than when we purchased, the lake is still NOT crowded, even on a holiday weekend. I have been on Conroe, Travis, and Lake LBJ on a weekend, and I wont do it again! Its crazy! We live on the far SW side of Houston (Sugar Land) and it takes us about an hour and a half or so to get to our property just outside of the town of Livingston on the east side of the lake. Access is easy, and HWY 59 is usually pretty quick. West side areas are not quite quick to get to because they are a lot farther from the interstate, but still a pretty easy drive. The lake level is much more stable than other lakes around the Houston area because of improvements the govt did a few years back, to the Trinity river. The last drought we had, Lake Conroe and Lake Houston were down by over 6 feet. Livingston was only down a foot! Lake Travis just recovered within the last year from a historic drought....they were down over 60 feet from normal level!
Some disadvantages: You do have to be aware of stumps in some areas, as I said above...but you can buy a map that gives you a good idea, and you learn the areas that are pretty stump free. The southern half is the least problem, and that is where we spend most of our time. Livingston is a huge lake, so wind can be a real issue. The water can get quite rough at times. In the summer, a storm can pop up our of nowhere, if you arent keeping your eye on the radar. You do NOT want to get caught out in the open water on that lake when a storm is brewing. My guide, because I have been caught twice and scared the crap outta the whole family.....If we hear thunder....we head for the house or at least water that is within a 5 minute ride. There are not alot of amenities in and around the lake such as restaurants, clubs, etc. because it is much more rural that places like Conroe, Travis, LBJ. But that is not necessarily a bad thing either....not as many people! There are not a lot of marinas, and those they have are pretty small, in the event you are planning on docking your boat, unless you get property on the lake and have your own dock.
I hope this helps....we love our place, and would not even consider buying anyplace else at this point. All of the lakes you are looking at are great lakes. Travis, of them all, probably the most beautiful area...but also by far, the most expensive! Good luck in your search!
haha good point. @bobbie That is exciting that you may be escaping the cold dreary north. I think there are a lot of great places to check out down here. I have only been to one lake in Texas which was Sam Rayburn Lake, and it was huge. There are some beautiful lakes in Tennessee, Georgia, South Carolina, etc. Good luck on your search. You will be glad you made the move!
We live in the Austin area and love boating here. 90% of the time we put in at Mansfield Dam Park on Lake Travis.
- Lake Travis is HUGE and has several bars/restaurants on it too.
-Lake Travis can be choppy on windy days but there are several inlets that are protected for good surfing
-Lake Austin during the weekdays is fantastic, water is like glass you'll maybe see a few other boats out there
-Avoid Lake Austin on the weekends. Too crowded for the size
Other lakes nearby: Lake LBJ, Inks, Buchanan, Marble Falls, Canyon Lake, Lake Belton.
The boating here is top notch but so is everything else. Music, breweries, BBQ, festivals galore.
http://www.kvue.com/news/local/us-news-names-austin-top-place-to-live-in-us/402438152
I live in the suburbs of Atlanta, but trying hard to get out of the area and traffic. My wife and I have been looking a lot lately in Greensboro, GA (i.e. Lake Oconee). It's about 90 miles east of downtown Atlanta. 1.5 hours from the Airport with no traffic. There is quite a bit of money around the lake so the area overall is really nice. While there is not a ton of commercial development, you're within 45 to an hour of several larger shopping areas (Athens, Augusta, Milledgeville, etc.). The key is its a no traffic easy 45 minutes. Cost of living is all perspective so I'm not sure how to compare against your current situation unless you give us an example of what homes, taxes, etc., are in Portland. You can definitely spend a significant amount of cash to be on Lake Oconee, but there are more reasonable properties not directly on the lake. Several interesting names you might know have properties on Lake Oconee (Frank Beamer former coach of Virginia Tech, Bruce Arians coach of Arizona Cardinals, Kirby Smart UGA's head coach, the often remembered/highly regarded Jetboater Mikey) to name a few. If you like golf there are several 1st class courses surrounding the lake. Ritz Carlton has a very nice resort of the lake that's a draw for the community as well. My wife and I will be moving to the area if our daughter gets selected in the lottery system in April for their public charter school that ranks as one of the top in the nation. I don't know your work situation, but I would highly encourage you to check out this area if you ever tour the Southeast. This is a really good video developed discussing the area.
Thanks all...we have to be a bit considerate of a gay friendly place or at least laid back city. Although anyone from the Shelbyville crowd will attest we are pretty easy going people
I would like to offer an alternative perspective, I have lived in London and spent lots of time working in NYC, DC, Los Angeles and the Bay Area. I like Austin. I once considered relocating there. When I took the family there for a week last summer I found myself considering whether or not I wanted to get back into the rat race. But for my family living in a small town with big lakes, lots of open land, mountains, trees and streams is perfect.
Even though Columbia, SC is a southern bible belt town, the people here are welcoming no matter if you are exactly like them or not, the only thing that seems to matter is if you are good people or not.
@Andy S. Well...we are definitely good people
Although the liberals on the left paint us all as KKK, homophobic, racist, monsters, most people in the south are friendly and look at others for the kind of people they are, not their sex, religion, race, or sexual preference!
Then Austin it is! :)
@jameskeller76 . We are headed down at the end of March to visit my brother and get some time on lake travis with shred stixx surf school!!
You will love Austin!
Just had some friends go to Austin and they absolutely loved it. Side benefit it's home to COTA and the F1 race in October.
