pltsman45
- Scarab
- 255 ID
Have a 2016 255 and recently have been getting some cavitation at around 35-4000 rpm's. Thinking it was a twig or something stuck on impeller, went to take a look and found the boot was damaged, basically the soft plastic part was chewed up. Which i think normally happens when you suck up a tow rope/dock line something like that, which i haven't done. Pulled the pump to find only a little bit of weeds wrapped around the drive shaft where the soft plastic part of the boot would be. Has anyone encountered this before? Could weeds wrap around this boot and damage it? Or do these boots just go sometime? Here is a pic of the damaged boot vs a new one. All the soft plastic is about gone and all that was left was the hard plastic. Put a new boot on and will see if that takes care of the cavitation.
