SwimBikeRunBoat
- Texas (Lake LBJ)
Reposting this as I now have video link up that I'm hoping helps with the diagnosis.
So went out for a nice evening cruise on the weekend and sucked something up, but nothing obvious in the cleanout port. Engine power down on starboard side. Limped back to dock - both engines running. Back at dock there was substantially more water in the engine bay (still way below the engines though) than I have ever had before. So troubleshooting yesterday I have discovered a tiny leak from what I think is the backside of the impeller housing which below 2,000rpm doesn't increase, but when I get up to 4,500-5,000rpm there is a visible spray of water coming into the engine bay.
I have attached a photo of what I'm calling the backside of the impeller housing (in case my terminology is incorrect)
In the video (link below) the water spray appears right around the 18 seconds mark of the video.
So what have I done - and then what do I need to do to fix it?
Thanks for any help
Thanks for any help
