4x15mph
- Downingtown, PA
I seem to have a bit of water when I take the boat out and remove the drain plug. It isn't always the case and happens sporadically. Based on the design of this 2018 AR210, I don't think the primary bilge, in the engine compartment, is anywhere near where the bilge should be since again, I often get water and the OEM bilge doesn't ever see any water.
I bought everything i need to put in a 2nd bilge and began to look at the install yesterday. Upon looking at this, I don't see a good spot in the actual bilge to place this new bilge pump (combined bilge with automatic float switch).
Has anyone installed a 2nd bilge in the back bilge/muffler area and do you have any pics or details on install?
Otherwise, are people living with this extra water? My anchor locker was fixed from prior owner so I think the water is coming in from the rear cleanout tray....
