veedubtek
- Punta Gorda, FL
- Scout
- Other
I believe you are correct, Yamaha manuals are a bit confusing and some of the stuff people assume is locktite is actually anti-seize. Like for the impeller... lol.I don't have the service manual in front of me but seems I recall actually using thread SEALANT on those bolts per service manual suggestion. Assuming it is for anti-seize/corrosion reasons.
I have an opposing view after a bolt loosened and fell into the carb body, then locked up an engine.
Sealant and Blue are not the same, the blue thread locker will release with hand tools, and will keep the bolts and nuts from backing out, and with luck will protect them from the elements compared to no thread locker. It can't hurt anything, worst case it helps. If you have it handy, my suggestion is lather it on. (especially if when the bolt backs out, it locks up the engine)
