HangOutdoors
- Royal Oak, MI
I would move the cable through the middle of the bracket then up. Also I would bolt the tranducer bracket to the inside so it is not wider than the transducer. Finally I personally would only use one bolt at the bottom so the transducer could kick up if necessary. Some suggestions, but otherwise it looks fantastic. You could also cut some different length arms and adjust on the water etc, to find out how high you can take it without degradation.
Great work!
Great work!
