MattFX4
- Marietta, GA
- Other
- Other
Hey @MattFX4 . I used a 5 inch hole saw for the 6.5 speaker holes. Based on what I found on your speaker choice (a very good one, by the way) you also have a 5" cut out. If you do not have a hole saw and don't want to pay the money, you can use a dremel or similar with the attachement to make circles. With the 10" Sub hole, I started that way but ran into issues with the bit loosening up all the time, so I switched to my jig saw and very steady hand. I drew the circle and followed it around with my jig saw. No matter what method you use, cover the entire area with masking tape to avoid much chipping and marring the gel-coat surrounds.
I mounted the EQ straight to the underside of the helm with 1" screws after drilling pilot holes first. I made a hole just large enough to pass the RCA wired through. That hole was tight. I fought with the last few RCA jacks getting through since there was additional wired in the hole taking up space. That hole was right behind the EQ and not noticeable.
For the Sub, make sure you have a ring behind it to mount to. As a matter of fact, I had to order a 3 pack and have no need for the other 2. If you do not have one PM me your address and I will send 1 to you free of charge.
Good luck!
Ah ok thanks. I already have a ring on order or would take you up on that offer. Thanks, Matt
