Wake_Dude
- AR195
I heard the vacuum line should point up. Is that true? I wasn’t sure.
You shouldn’t be generating enough positive pressure at idle to create any engagement by the BOV, only after you’ve built boost and let off the throttle.I guess normal...
Mine is basically sitting on the intake tube, they are definitely touching. Hope that is not an issue, if it is, guess I can try to zip tie the intake tube a little closer to the hull. If it's not an issue, I will just leave itI went for the red
Is it normal for there be barely enough room for the intake tube to clear?
I am also a novice. Have yet to take mine out after I did all of this, hopefully this weekend weather permitting. The thread basically explains what all 3 do, the BOV saves/prevents your super charger clutch by blowing off all of the excess pressure. The air filter has to be changed out on 2018 and older models so the BOV can fit, plus it can't hurt performance obviously, and gives you much more room in the engine bay as well. The catch can catches all of the nasty oil gunk and whatever else and only puts clean air back in. Don't know if I explained all of that right but that's how I interpreted it. Griswold seems to be the mastermind here, I am just a student of the game right now?. I'm not sure it will give me any performance enhancement in general, but I know it will help with the longevity of my engine, and save my super charger clutch from ever needing to be replaced, which in IMO for the around $300 price of everything here and a few hours of time gives me piece of mind and makes it well worth it.I take possession of my 2020 195S this week and this thread was a lot of fun to read. Being a total novice with performance modifications, I'm wondering what performance gains (power or otherwise) are to be had with the three main mods on this thread:
I have a basic understanding of what each part does, but not sure how the job it performs translates to gains. Aesthetically though, these posts look awesome, especially when the components are color matched.
- Blow off valve
- Oil catch can
- Cold air intake
Ya man I know that. Sorry for the typo! Thanks for clearing that up@Crob83
Just to clarify for everyone. Supercharger, not a turbocharger. Hope everything worked out. Let us know your impressions!
Pardon my ignorance regarding BOVs, but would the 35 mm BOV work? Does it have physically smaller outer dimensions? I understand the concept of why a BOV is beneficial, just not sure what the pros/cons would be of the 35 vs 50 mm. I'd like to retain my stock airbox. Thanks.
Curious about the little breather filter on top of the catch can. Wouldn't a closed system provide more efficient crankcase pressure evacuation? I've seen many forced induction engines in the auto world utilizing catch cans that aren't vented. Not wanting to start a debate, just wanting to know the rationale. It seems that pulling a constant vacuum on the crankcase while filtering/catching the gasses would be the best of both worlds. What am I missing?
Here is some good reading:
Vented VS. Sealed Catch Can?????
Why is a vented can not optimal for "these" vehicles, when every company in the market offers them as vented? I personally have installed numerous catch can setups on alot of cars, granted I never have on a dsm so my question is what makes these different from any other boosted application? I...www.dsmtuners.com
The 4G63T PCV System
IntroductionWith very few exceptions, no topic generates more debate than the PCV system used on our turbo DSMs. I think it is mostly because of the huge amount of confusing and sometimes misleading information that has been posted in the forums over the years. It is for this reason that I...www.dsmtuners.com
I'll be running my setup with the provided bolt in lieu of the breather.
The size of the BOV is dependent on the engine size and boost. 35mm BOV is plenty for the 1.8l SHO engine.
I'm not running a breather on top of my catch can. Don't want the vapors circulating in my engine bay.
