JDFester
- Loganville, GA
A couple of weeks ago while pulling a couple of kids on the tube, I got a low oil pressure alarm and speed limiter kicked in. Stopped and checked the oil; it was low. (My fault, I had gotten complacent and hadn't checked it as often as I should...). Added oil to middle of range on dipstick, started and tried again. Same thing after running about a minute at speed with the tube. Pulled in the tube, rechecked oil (no change, still middle of crosshatch on dipstick). Close to ramp, so rode back at low speed and called it a day.
We had not really wintered this year, so I had not done my usual annual oil change, so I did that yesterday morning. Got oil as close as I could on the trailer, but then ran, stopped and let it sit a couple min in water, and rechecked; added oil up to center of crosshatch region, started, and tried to take off. Almost immediate low oil pressure alarm. Check oil again, where it should be. Start again, and try accelerating more slowly. (i.e. ~1000 RPM steps, and run at that speed a min or so then bump up another 1000. This seemed to work things out, as I was up and running full speed like always, able to start, stop, everything like normal. Run up and down the lake for an hour, then head over to a park and dock for a couple hours. When leaving the park, we idle out of the long no wake zone, then try to accelerate, and almost immediate Low Oil Pressure alarm. Start trying the slow increases again, and notice that when I would bump up, it would drop a couple hundred RPM (i.e. I go to 4K, and after a couple of seconds, it drops to 3800 and stays there). Get to 5K, low oil pressure alarm. Did this twice, then idled the rest of the way back to ramp and pulled boat.
Can anyone give me other ideas of what I should check next? Thank you!
