The wires go to the stator that also feeds the rectifier.regulator.
The AC from the stator heats the wax capsule and closes the enrichment valve.
It is only passing fuel when the engine starts for the first time or until it cools when the stator is not producing power. There is no switch in the circuit.
Please read the section on setting the carbs and timing I posted.
The carbs open a little at idle and then move very little until you get closer the WOT.
The engine accelerates on timing advance in the midrange.
Set the timing as it is specified as in the book and you will be a lot further along than random changes.
For the enrichment valve to work the throttle plates MUST be completely closed! There are holes in the plates for air during idle.
A short shot of ether starting fluid (with lubricant included in the can) might help get it running, but if the setup is correct you should not need it.
RTFM (Read The Fine Manual!) I posted the applicable parts.
