Big Mo
- Breaux bridge La
- Limited S
No problems at all..took about an hour and a half..theres also no curing time so i went straight to the lake afterwards with no adhesion problems..must have for beaching..make sure you etch it good with the provided scotch padNice! That's something I have to get done in the next week or two. Any issues with the install?
No drag at allAny drag issues or anything?
I definitely recommend it..i usually dont beach either but where theres no docks avaliable, its nice to have that optionI have been thinking about this as well. We usually don't beach but if I wanted to this would make it better. Also may help if I hit a submerged log or something like that. Thanks for sharing.
Looks good !!! I am installing one this spring !!! any tips or tricks?So i installed the Megaware keel guard today on my 242 and here are the picsView attachment 33860 View attachment 33861 View attachment 33862 View attachment 33863 View attachment 33864 View attachment 33860
Well just take your time, get a friend to help and follow the instructions to the T!! Wasnt bad at all thoughLooks good !!! I am installing one this spring !!! any tips or tricks?
Yea that a round about..I paid $189 off amazon for the Megaware. A 9ft keel guard is recommended for out 24ft boatsIs $200 about the average for these things for a 24ft boat?
I am putting the keel guard from gator guards on today or tomorrow. When reading the directions it recommends (but also states not needed) sealant around the edges to help with sealing it to the hull. I assume more of a overkill step and if you ever had to remove a PITA. Any thoughts?No problems at all..took about an hour and a half..theres also no curing time so i went straight to the lake afterwards with no adhesion problems..must have for beaching..make sure you etch it good with the provided scotch pad
Hmm..not familiar with that brand but Megaware required etching the surface the width of the keel guard..the primer with the adhesive forms a very tight seal...I would just observe the seal and edge of the guard after install and make a decision at that timeI am putting the keel guard from gator guards on today or tomorrow. When reading the directions it recommends (but also states not needed) sealant around the edges to help with sealing it to the hull. I assume more of a overkill step and if you ever had to remove a PITA. Any thoughts?
Great!!! Where are the pics?Put it on this morning in about 45 min with help from the wife. I didn't seal the edges just install same as you and my instructions described. I did focus on the ends and edges as installing and went over them with extra care but nothing special. Immediately took it on the water and inspected after no concerns. Success!
