anmut
- 212S
We took a trip to Madison, WI this past weekend to boat on the chain of lakes. The lakes are really pretty, big and deep for water sports. On the two larger ones, you can see the state capital building from water, which leads to some really nice pictures.
However, our trip was interrupted by milfoil (not to be confused with Milf Oil, as my cousin called it - which would've been a lot more fun). If you've ever had to deal with this invasive species with a jet boat, you'll know the pain I'm about to describe.
First time we tried to get dock at a restaurant from the water. I saw the patches of milfoil on my way in and tried to vary the throttle speeds keep the pumps in "blender mode" - this has been successful in the past when dealing with other weed areas. What I didn't realize is how milfoil clumps up. Within a minute I had an overheat warning on the port engine. We got to the dock, and I spent the next 20 minutes trying to clean out the pumps through the cleanout port. My wife then noticed the "no dogs allowed" sign so after all of that work, we weren't eating there anyway. So off we went on one motor, trying to navigate out to cleaner water. I was unable to clean out the pumps through the access manholes - so eventually I donned my daughters pink swim goggles and jumped in the water. Pulling the weeds out from under the boat was MUCH easier - most of it was jammed up against the grate and didn't need a lot of strength to pull out. A few restarts to check the pissers and continue to clean the pumps out and we were on our way. Total down time was probably 45min, however, I could've been done quicker had I jumped into the water to being with and not even bothered with the clean out ports.
On the next day, the same thing happened as we cruised back to the boat landing to pick up some extra riders. However this time I didn't get an overheat warning, I could just tell that the pumps were clogged by the way they sucking air at high RPM. Taking the previous day's lesson into account, I quickly jumped in the water and, a few held breaths later, I was able to clean everything out and get on our way again.
If I can share some lessons learned:
On a funny note, on our second day putting in at the boat launch I had a nice young lady come over to us as we were prepping to put in and ask me if she could ask some questions about invasive species... I was like "I think you're a little late to the ball game here..." which got a pretty good chuckle from her.
- If you see milfoil, avoid it at all costs. You won't chop your way through it. If you have to go through it, get a running start, and shut your motors off as you glide through, restarting when only when you need control of the boat again.
- If you get milfoil jammed up, jump in the water and dislodge from the intake grates - you're asking for a long day and rapped knuckles if you try to do it by hand through the cleanout ports.
- If you are on a lake like we were and they take part in milfoil "chopping," avoid the sides of the lake where the wind will push those floating masses.
- If you're wake foiling on a lake with milfoil, and find yourself suddenly diving in the water for no reason, congrats - you just hit a milfoil patch.
