This is the warning I got in my iphone, which I was talking about earlier! I did not take the pic of it, and don't know how to recreate the conditions, but the app is definitely doing something in the background AFTER it is supposedly off.
I'm not on facebook, but I liked your post here .I posted about this on Navionics Facebook page. If you are on Facebook please like this https://www.facebook.com/photo.php?fbid=10154695752894720&set=o.111050969965&type=3 and maybe we will get an answer.
Shoooooweeeee
Ok, I finally made a decision.
Simrad GO5 XSE with Nav+ Mapping and Med/High/DownScan Transducer
http://www.thegpsstore.com/Simrad-GO5-XSE-with-Nav-Mapping-and-MedHighDownScan-Transducer-P4835.aspx
This got me a transducer I can shoot through the hull. It comes with Navionics +. I like the touch screen, and by using a template, I think I can get it to fit nicely in the dash.
Slightly over 5 bills, but looks to be a good unit. I will post install and results as I go.
Were u able to get this done, i want to do the same thing. is there a thread on the install and pics?Clean unobtrusive mounting locations for the display are limited on the newer 24 footers and I would guess the same for all of the models. I am planning on installing a Simrad go7xse at some point as it suits well to an in dash install.
My plan is to remove the dash hood and modify for enough height (about an inch is needed) for a new dash panel that will house the simrad display where the tachs are now new to the connext screen. The tachs will be in angled recesses in the top of the dash hood. To do this I plan to make a carbon fiber laminated dash panel to hold everything and rebuild what ever I have to cut on the dash hood to match the panel and meld into the remaing hood. A final carbon fiber laminate on all of it to make it look better than factory.
Just throwing that out there in case someone can make use of the idea. I plan to use my airless sprayer as the vacum pump and space bags for the outer bag so I don't need to buy too much equipment for my first carbon fiber project. Don't know when I will get to it but something I really want to do.
I will be searching through the threads to find a great install, seen on the thread on the Garmin units now I'm torn between that and the Simard GO units. I'm also wondering about transducer mounting on the transom. I will be putting Lectrotab trim tabs, so its going to be tight on space.I never did this but somone found a different 7 inch brand/model that fit well. I am not remembering who.
